arcon 3 Report post Posted May 8, 2014 ok this is the 4th time this has happened in as many years. airbag light on for no known reason. last 3 times i took it to the same shop, was always "seat-belt tensioner needs repair, $200". yeah 3 times for the same issue is enough lol. so i was thinking to actually take it to BMW but... uh... not sure i trust them either as far as value. any recommendations for reputable places on the Shore that could sort this...? thanks in advance. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 8, 2014 What did they do / replace for the $200 and was it the same seat ? Quote Share this post Link to post Share on other sites
arcon 3 Report post Posted May 8, 2014 same seat (driver's). just mentioned "belt tensioner repair", don't know specifics. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 8, 2014 (edited) The Tax invoice should be specific and detail the work carried out (labour) and the parts used. It would help if you would like help with your problem or give me a call on my mobile.. 021921377 Edited May 8, 2014 by B.M.W Ltd Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted May 8, 2014 Just buy a seatbelt buckle with the pyro pretensioner on it for the correct model year from a wrecker or the likes and install it yourself and ask someone on the forum with a scanner to the clear the codes ... those pretensioners are like $50 from a wrecker. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 8, 2014 95% of the time it is not the pretensioner that fails Tom Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted May 11, 2014 probably your occupancy seat sensor Quote Share this post Link to post Share on other sites
arcon 3 Report post Posted May 13, 2014 was a quick fix - took it to Burger's on Wairau, was wiring / poor connections to airbag. Quote Share this post Link to post Share on other sites
