Tristan 338 Report post Posted May 12, 2014 Question for the wheel gurus, How much (if any) work will it take to get the OEM 19" E92 M3 wheels onto an Msport E90 Pre-LCI The suspension will not be touched. Thanks Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted May 13, 2014 Quick search shows that the M3 set up is 19x8.5 ET29 / 19x9.5 ET23 while e90 is 35-40. My guess is depending on tyre sizes, probably not a lot, a quick roll and should be sorted. Quote Share this post Link to post Share on other sites
Driftracewake 22 Report post Posted May 13, 2014 Straight on... Even with the m3 tyres if your not to low. Ideally you would go a size smaller tyre to keep the rolling radius the same. This is a mate of mines 335i we fitted the e90 m3 wheels too.. http://www.trademe.co.nz/motors/used-cars/bmw/auction-727295452.htm He has changed the rear tyres only. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 13, 2014 Are the E92 m3's unlike the E46 in the they were quite different to the std car? Quote Share this post Link to post Share on other sites
