Lukeprusher 13 Report post Posted May 19, 2014 (edited) So i have swapped my doors, and 1 door has manual and my original door has electric windows, i am trying to strip my electric windows, but the window reg does not work, so window does not go up or down, and the bolts connecting to the window cannot be reached. How would i get the bolts undone Edited May 19, 2014 by Luke P Quote Share this post Link to post Share on other sites
aja540i 1922 Report post Posted May 19, 2014 (edited) You will probably have to connect the motor back up and move the window to a position where you can reach the bolts, unless you can remove the motor and move the window by hand.(Or just hotwire the motor off a battery to move the window!) Edited May 19, 2014 by aja540i Quote Share this post Link to post Share on other sites
