39KiwiTouring 2 Report post Posted May 22, 2014 Hi guys. Any help appreciated here, Here are symptons of my trans potential issue. 1. Is very tall in first when cold changes to 2nd at 3500rpm and when i'm at 40k. 2. I have had to use the tiptronic or manual part to change into 5th when doing 100k as it seem to be sitting at 2500rpm so dropped to 1700 odd once in 5th, had to do that a dozen times not all the time. 3. Has started not dropping back in to 1st when stopped at lights done this a few times probably half a dozen times then takes off slowly pinking abit because it's in 2nd or even third, then realises and kicks down and gives the diff a whack while it's at it. 181k kiwi new so I might explore BMW service records if they have changed the trans fluid but it looks like the lifetime seal sticker is still in tact. Suggestions please. Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted May 23, 2014 Have you checked tyre pressures, diameters and wear? They can upset the trans. Quote Share this post Link to post Share on other sites
39KiwiTouring 2 Report post Posted May 23, 2014 It has 55 on front and 50's on the rear, as in 225x55x16 Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted May 23, 2014 Hmmm... that could be it. They don't much like different rolling diameters. Quote Share this post Link to post Share on other sites
39KiwiTouring 2 Report post Posted May 24, 2014 Yes sounds like it is engine and trans have always run superb FSH etc. Just noticed the tyre size difference since this thread. Quote Share this post Link to post Share on other sites
39KiwiTouring 2 Report post Posted May 24, 2014 And I only put those tyres on a few months ago Quote Share this post Link to post Share on other sites
FuManChu 2 Report post Posted June 2, 2014 I'd check if the trans has had a service too. I did mine at 160km nz new and the oil was black! Yeah on the tyre thing too. My trans guy said he come across a worn spare tyre on the rear throwing the trans out of sync. Quote Share this post Link to post Share on other sites
