KwS 2450 Report post Posted May 31, 2014 Hi all, in the middle of doing my vanos and i have hit a real snag. I cant find my TDC marks T | O on the crank pulley. I have lined the cams up so the lobes are at 45 degrees pointing to each other, and i can see the pointer on the timing case, but no bloody mark on the pulley. i have spin it over a couple of times watching the pulley and cant find it. Anyone with a 3.0 know where they are? The set up is slightly different to the 3.2 engine. Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted May 31, 2014 Found it, behind the toothed wheel >_< Will put up pics to show where it is in my thread once im done. ONWARDS! Quote Share this post Link to post Share on other sites
