nz320i
Oil in the AFM what the???...
i was taking the afm off for some reason the other day, and where it mates with the rubber bit that goes to the throttle body, there was a little bit of what looks like oil in it, say a small bit like 1cm x 1cm and only in this place, and was still moving ie not hard or dried.
Any one else had this? its not much but it must mean something.
any help appreciated
CHeeer :bounce:
Could come from a backfire or an accumulation of intake sh*t, my afm needed a good clean as it was layered in gum and other sh*t
that would be right, as i am getting back firing sometimes for some reason? is it running to rich? i dont want to change it as i dont want to run it lean and start getting problems? is there a fix for this? thanks
Talk to Udit about backfires as he's experienced a problem with them in which it blew his entire intake apart so he may have some advice
Udit = DCEIVN
Edited by ///Carl
