Michael.
Universal Auto Transmission Controller PCS TCM-2000
Hey guys, going manual so not requiring this piece of gear anymore. Asking $950
With this unit you can control almost any 4-6 speed automatic gearbox, an amazing tool!
Email me or reply here if you have any interest!
Includes:
1x TCM-2000 unit
1x Universal harness
1x USB Lead to laptop (usb got damaged, but has been repaired)
Specs:
The TCM-2000 is the most powerful aftermarket controller for automatic gearboxes
Features dual calibrations (sport mode, tow-haul mode, etc.), programmable shift points, shift firmness, and torque converter lockup.
Unique to TCM-2000, PWM outputs are programmable either active high or low supporting a wide range of transmissions from GM, Ford, Chrysler, Nissan, Toyota, and others. The CAN interface allows seamless integration with CAN based vehicles or ECU's. Compatible with J1939 and other CAN standards.
The CAN connection also simplifies the connection to a PCS Paddle Shifter or GSM-2100 Gear Select Module so you can eliminate the shift lever in your car.
Edited by Michael.
