jayzrb 1 Report post Posted June 22, 2014 Ive bought goodridge brake hoses for my e30. But its only a 4 hoses, i found out later theres 2 more hoses at the rear. Should i get the rear inner braided hoses or just get new ones from the shop. If so.. know any shops that sell inner hoses ? Or should i just leave them and change the 4 Quote Share this post Link to post Share on other sites
///MPROVD 135 Report post Posted June 22, 2014 mixing the hoses is not going to give a more responsive feel like it would if it were complete, But it cant get worse i had the same problem so i brought another 6 hose kit but when it arrived it had US spec front lines that were to short, so i used the 4 line kit front lines and the back set for the rear end. finally i ended up using one of the US front line as a clutch line and worked well. so ive got 1 US front line male-female 2 back caliper lines male-female $30 each Quote Share this post Link to post Share on other sites
jayzrb 1 Report post Posted June 22, 2014 Ive got the rear caliper ones male female. Il get the us front line male female off you. Il use it for my clutch too. Will the male female work on the inner? Quote Share this post Link to post Share on other sites
