Eagle 1782 Report post Posted August 9, 2014 Thanks to NZ ****ing post the gasket has been split but nothing a little sealant wouldn't fix or you can reuse your old one if its good. Will fit any BMW with a ZF 5HP24\A4S440Z automatic transmission found on M62 4.4L V8's. Brand is Febi Bilstein Part no:24341422673 $45 Quote Share this post Link to post Share on other sites
