Blackfrogg
M50 thermostat
Can just use one hose to return directly to the manifold. Is a cold weather climate thing to prevent condensation from icing up in the mani apparently
If it makes you feel any better I did the same on my 325i after breaking my third one of the temp probe thingies. Nearly 2 years ago and no ill effects. Up to you though :)
If you do go ahead with replacing it I advise buying new rather than used. The plastics suffer the same fate as all other cooling bits, goes brittle and craps out - two of the three on my car came apart by themselves.
Edited by Ahmedsinc
