Guest MP0wer Report post Posted January 9, 2015 (edited) While on a holiday I came to my car parked outside the motel one afternoon to have found it broken into, they managed to open the passenger side door, removed the door window trim plastic piece, screwed in all the door locks including the rear one too. my coupes passenger side door lock no longer functions. I will either take it to a lock smith (broken wafers?) or just leave it. If anybody got a spare/wrecking e36 coupe I need some small parts to fix up mine.. 1x front passenger side window trim piece (this is from a e46 but its similar to what I'm after http://www.m3forum.net/m3forum/showthread.php?t=449934 ) 1x e36 door handle microswitch (not so important but it comes in the 94 - 95+ models) http://www.frankies-bmw.com/3series/diy/microswitch/images/microswitch_part.jpg I could also use some door lock outer rings as mine are all bent with the force of the screw driver(these go on top of the actual lock tumbler and are very easy to pop out with a screw driver and pliers.., will show how but not so important if you cant be bothered. anyhow if anybody here can help me with whatever, give me a shout.. edit: I'm in dargaville northland, will cover shipping happily... Edited January 9, 2015 by MP0wer Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted January 9, 2015 You don't exactly make it easy by not telling us where the hell you are. If you tell where you are there is probably someone on here that will help you. 1 Quote Share this post Link to post Share on other sites
Guest MP0wer Report post Posted January 9, 2015 You don't exactly make it easy by not telling us where the hell you are. If you tell where you are there is probably someone on here that will help you. I am near dargaville/northland Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted January 9, 2015 Bit far away to invite you over to look at what I have then. Quote Share this post Link to post Share on other sites
Guest MP0wer Report post Posted January 9, 2015 Bit far away to invite you over to look at what I have then. Cheers, yea...unless you could be bothered to pull it off your parts car, just takes a screw driver to pry it out...will pay for the post and whatever.. Quote Share this post Link to post Share on other sites
Guest MP0wer Report post Posted January 9, 2015 okay thanks. Quote Share this post Link to post Share on other sites
