JordanLee 6 Report post Posted February 16, 2015 Hi guys I realize this issue has been raised a lot, but I can't find any help on it. I'm doing an m50 swap, and have the opportunity to get a full 5 speed conversion from a e36. Does this getrag 220 fit onto the trans mounts? And does it sit properly with the e30? Any help is appreciated bad or good Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted February 16, 2015 It's identical to using a 240 318i e30 box. Use 320 driveshaft / linkage and e30 gearbox mount. Only difference is you need a e36 slave cylinder. Quote Share this post Link to post Share on other sites
JordanLee 6 Report post Posted February 16, 2015 and you dont need to custom tranny brace? also with the shifter hole line up or will that need custom too? Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted February 16, 2015 Like I said, E30 gearbox mount and 320i linkage. Quote Share this post Link to post Share on other sites
