E30nut 1 Report post Posted April 20, 2015 Hey guys, ive got a real random issue that came about with my E30 was driving, and smoke started pouring from the windscreen demist vents, which was then followed by a sudden spillage of coolant in my passenger side foot well.... seeing as when i start the car now the temp guage jumps waay high id assume its definitley a cooliong problem.... i need help to get it fixed asap .... help will be appreciated... thanks Jordache D Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted April 21, 2015 Heater core has probably burst. Quote Share this post Link to post Share on other sites
E30nut 1 Report post Posted April 21, 2015 AllanW what could be the cause ?? and is it an easy if i replace it ? Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted April 21, 2015 Stop running the engine... don't cook it! I wouldn't say easy... no. But a LOT easier than a lot of other cars - The dash doesn't have to come out for one thing! Google E30 heater core repalcement. There are metal pipe versions, and plastic pipe ones, and you need the correct one for your car. Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted April 21, 2015 Cause can be crud in the heater box, corroding it from the outside, having run with out antifreeze corroding it from the inside, but there was a BMW recall MANY years ago about it, but that was just new radiator cap I think - Dads had it done late 90's I seem to recall. By now, most likely corrosion. Quote Share this post Link to post Share on other sites
