SRBMW
pre F/l 318 manual wrecking
Hey guys wrecking a 84 e30 2door done 217kms,.Interior is pretty shot
Engine with computer and loom hoses coil etc $200
Airflow meter $20
Passenger head lights $30
316i small diff 1:3.25 ratio$40
Drum rear end $50
rear shocks $20
Front struts with vented discs calipers and shocks $40
Rear tailights $30 each
Glass etc windscreens
16'' motoform 4x100 mags$250 will post pics soon
wind up windows
No sun roof
If any body would like to come cut pieces out to repair their e30's just let me know
will be posting on trademe soon so be quick
Please call dont text especially you bloody 027ners!! :P
0211645663
Edited by SRBMW
hey i want the diff please. what ratio and its small nugget right? called you.
Edited by nz320i
Hey guys heres the pics of the mags, they came off an e30.I'll tell ya the offset tomorrow.They have kurbing on most of them but with a bit of work these wheels could be nice .The tyres all have good tread but have some cracks in the side walls so would be all right for a while.
cheers
Oh also this car is cream and has a nice poo brown pin strip down the sides so if any ones interested I might be able to peel it off in one piece :D .Let me know!!
I have also got some receipts for work done on the motor and the clutch was replaced in 2004 along with master and slave cylinders and engine mounts
I have sold the gearbox but still have the
Pedal box master cylinder
gearbox cross member
Starter
Flywheel and crank bolts
Driveshaft
Wanting $200
Still got the engine and a few bits and pieces.
If any one is after the lower lip that goes on prefacelifts they can have it for free!!!
Im after rear muffler, is it single in single out? i need it for my 85 320i? are they the same? and i need it from the slip joint so i can just slide my after market one off and put this 1 on for warrent
