ssharma_akl
2012 528i ex-Japan TV region settings
Hi
I have recently purchased a MY2013 528i ex-Japan. The CIC unit is upgraded to NZ Radio and Nav but the TV settings still show Region Settings for Japan and there is no menu item to switch the Region to AU/NZ. How do I go about changing that? Also, do these CIC units come with Built-in DVB-T tuners? The manual says they do......Any help will be great. Tks
Hi there
I don't know how to change the TV settings. I bought a 328i 2012 from Japan which has TV feature. I have read somewhere that TV couldn't be tuned as the NZ TV broadcasting changed to digital.
By the way how did you upgrade to NZ radio and map? I need to upgrade mine too
Cheers
Hey there and welcome, suggest you call Joe at Eurosurgeon or Auto Gravity, both forum sponsors and great to sort this out for you, both a pretty late model but this guys should help
