Apex Effects 3 Report post Posted June 27, 2015 (edited) need some strut housings for some coilovers i'm putting together also in need of some rear 65mm 127mm long springs in preferably 9-10kg rates current ones are too long 0273095558 thanks Edited June 28, 2015 by Apex Effects Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted June 27, 2015 I have some 45s here if any use to you? when i did the coil overs on my touring pretty sure they cut more or less back to the hub anyways, so don't think there is any advantage of 51mm over 45mm in E30 case, except for if you need provision for ABS sensors. or are you using cheap and nasty screw in coil overs? Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted June 27, 2015 na was just thinking of using these as from pictures the 51s look like to have a bigger base. if they are the same sweet how much for the 45s? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted June 27, 2015 nah all the same below the shock sleeve except provision for ABS casting or not etc. i should have a bit of time tomorrow arvo ill put the 51s along side the 45s i have here and confirm (can't sell the 51s i have here sorry, they are the original ones from the cabby.) Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted June 27, 2015 (edited) thats all good. if the 45s are the same at the base then thats all i need, keen for them but if you can grab that picture for comparison that be fantastic cheers Edited June 27, 2015 by Apex Effects Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted July 2, 2015 bump Quote Share this post Link to post Share on other sites
