Jemzzz 0 Report post Posted July 7, 2015 Anyone ever done this swap before i have a few questions id like to ask thanks! Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted July 7, 2015 Yup. Not hard, just need patience & skinny arms, a little common sense, some time and the right tools What ya need? Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted July 7, 2015 yes many times Quote Share this post Link to post Share on other sites
Jemzzz 0 Report post Posted July 9, 2015 Thanks for the reply guys! Ive got the box on, everything on, cranked it, only the starter is spinning, wont engage flywheel. What ive tried: -chsnge starter -clean the ground strap on engine - clean contacts on starter -check wiring all right Dont know what else to do running out if ideas help!!!! Quote Share this post Link to post Share on other sites
Jemzzz 0 Report post Posted July 9, 2015 Also additional info, M50b25 jap import Getrag 5 speed M52 Clutch kit and Flywheel Quote Share this post Link to post Share on other sites
will 169 Report post Posted July 18, 2015 Firstly, is the solenoid throwing the starter gear forward when spinning up? If no, sort the starter/wiring/grounding/battery out. Battery could be the demon here if it is flat/weak etc. If yes, did you install the flywheel hard up against the crank or did you use the spreader/shim (example shown here as part #10 http://bmwfans.info/parts-catalog/E30-2-doors/Europe/325i-M20/R-M/1987/browse/engine/flywheel_twin_mass_flywheel/#pos_10 )between the crank end and the flywheel? (seen this done a few times now by certain to remain unnamed persons with the same outcome as you are having... ). Any doubt here, you need to measure the distance from the rear block-bellhousing mating face to the front face of the ring gear and then check that the starter gear shows sufficient forward travel to properly mesh with the ring gear. (I am too far from my shed right now to measure what the block-flywheel gap should be- and it is belting down outside!). Quote Share this post Link to post Share on other sites
