_Matt_ 42 Report post Posted July 10, 2015 anyone out there have one or two of these lying around? I believe it's what is stopping my E28 from starting since one doesnt pass the resistence test. I'm moving house in a week so it's rather bad timing. Anyone got some working ones? dont care if they are bad condition, I'm buying new ones anyway, I just need to be able to drive it to my new place. TIA Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 11, 2015 swap the 2 around (at both ends) , car will run on the one sensor , the main one is the one that works on the small trigger mark on the flywheel , the other runs on the flywheel teeth , but not that important to make it run , I take it ,its the factory e28 535i motronic setup? not converted to a e34 type setup? Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted July 12, 2015 yep, factory setup. out of a 635i I believe. Swapped them with no luck. I'm only getting one correct resistance from point 1 to 2 of a single sensor, 1060ish ohms. Every other point on both sensors fail to read anything. The other points are suppose to shoot up to 100 000+ right? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 12, 2015 did you swap at the gearbox and at the top where the plugs are Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted July 12, 2015 I swapped the sensor positions and also tried turning the engine over with the plugs both ways around. Quote Share this post Link to post Share on other sites
