Valvebounce 2 Report post Posted August 5, 2015 I scored a Reinz head gasket set for my M20.Real nice kit. But there are a few bits in the set that I can't find homes for. One large O ring, (Larger that the sqaure section one from the outside of the cam seal carrier) One small O ring (smaller that the two on the oil drain tube) And two pairs of Shims Any idea where these bit belong? Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 5, 2015 big one looks like a water pump seal, dunno bout the rest Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 5, 2015 Big one will be thermostat seal, Cant think of the rest though Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 5, 2015 Little ring might be oil housing bolt seal? Or do the M20s use a screw on type filter? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 5, 2015 ^^^^^^ Yep spin on Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3006 Report post Posted August 5, 2015 The silver rings are sealing washers not shims (I think), go under things like the temp sensors to stop them leaking. If you haven't stripped the head right down then they probably don't need to be replaced. Not important bits anyways... Quote Share this post Link to post Share on other sites
Valvebounce 2 Report post Posted August 6, 2015 I just unbolted the thermostat housing whole when I had the head pressure teasted. I was concerned about torquing the head down, only to find I'd missed something which couldn't be done insitu. Many thanks for the input guys. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted August 7, 2015 (edited) Large one, could also be the seal for the oil cooler thermostat right angle thing or just the thermostat hard to tell haha, small one dipstick, crush washers for sensors and one will be for the sump plug.. M20's have a spin on and no filter housing. Edited August 7, 2015 by antil33t Quote Share this post Link to post Share on other sites
Valvebounce 2 Report post Posted August 23, 2015 The four shim/sealing washers were indeed for the two temp senders. A spare t/stat housing I have also had an extra pair of hex bungs in it which would account for the other two washers. The baby O ring is still a mystery. Quote Share this post Link to post Share on other sites
Guest cortez Report post Posted August 24, 2015 Hi Bart .. maybe there for that lawn mower ? Quote Share this post Link to post Share on other sites
