ceebee05 1 Report post Posted August 8, 2015 With all the rain lately my E39 is retaining some water between the rear door seals. Anyone experienced this? Quote Share this post Link to post Share on other sites
rusteee 52 Report post Posted August 8, 2015 (edited) Do you mean when you open the doors, a puddle of water gushes out? If so its most likely the vapour barriers, the seal may have come off, or have been removed in the past and not stuck back down properly. I had that problem on all 4 doors of my 530, one having been cut with a stanley knife by some rough bugger doing some work on the door. Bit of black mastic sealant to stick it back down fixed the problem. Edited August 8, 2015 by rusteee 1 Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted August 8, 2015 What he said^^^^^^ Common as muck. Use butyl sealer or tape to stick it back down. Then you can get them off when required. 1 Quote Share this post Link to post Share on other sites
ceebee05 1 Report post Posted August 9, 2015 Thank you both for your help. Do you mean when you open the doors, a puddle of water gushes out? If so its most likely the vapour barriers, the seal may have come off, or have been removed in the past and not stuck back down properly. I had that problem on all 4 doors of my 530, one having been cut with a stanley knife by some rough bugger doing some work on the door. Bit of black mastic sealant to stick it back down fixed the problem. Quote Share this post Link to post Share on other sites
rusteee 52 Report post Posted August 9, 2015 No worries, but as Allan said, make sure it is some sort of mastic/butyl type sealant that doesn't cure so it can be removed in the future if needed. Quote Share this post Link to post Share on other sites
