jin108 25 Report post Posted August 9, 2015 Does anyone have a spring compressor I can borrow? Need to change out my front shocks. Also is there a recommended alignment shop? Im swapping out the front arms and rods with M3 bits and will be able to dial in some extra negative camber. Would like it done properly with before and after print outs. Quote Share this post Link to post Share on other sites
M3AN 4198 Report post Posted August 9, 2015 (edited) I have two here you can borrow if you pick up from Hillcrest on the North Shore... Can also recommend a couple of alignment shops in Wairau Valley if that's suitable. Edited August 9, 2015 by M3AN Quote Share this post Link to post Share on other sites
jin108 25 Report post Posted August 9, 2015 Hey thanks im in sunnynook can probably walk to where you are lol. I'll send you a PM. Quote Share this post Link to post Share on other sites
