shanew
1987 E30 318 project with SR20de
The time has come to sell off the project car as I don't have the time or energy to finish it off.
Ill see how much interest there is selling at as a whole package and if need be I will then part it out.
Brought the car about 6 years ago, Car has its rego on hold.
The car is a rolling shell with as far as I can remember just about everything there.
What it comes with.
E30 rolling shell
2 x bucket seats
Recovered rear seat with extra padding added to the sides and middle.
Dish steering wheel and boss kit.
Wilwood peddle box with Bias adjustment for brakes, Brake master cylinder position has been moved over to the drivers side to avoid the heat from the exhaust.
Dash has been recovered in faux Suede to cover up a few cracks.
2 x Sr20de engines 1 is a short block that was being used as a dummy motor for mock up, Currently sitting on temp engine mounts. The other engine was apparently a good running engine that comes with an ECU.
Sr20det Gearbox, comes with a short shifter, 5th and reverse where maybe a little crunchy, Also comes with the sr20det jack shaft.
Carpet that has been redyed.
Face lift loom fitted.
Looking for offers around $1500.
Bump, Willing to part out bits if required.
