hunter 413 Report post Posted September 21, 2015 Hi guys, looking for some advice on adjusting my front sway bar, have read conflicting reports on whether this should be done with both wheels off the ground as to have no pre load on the bar when adjusting vs. adjusting one side and then lowering the car tothe ground to do the other side. What have the suspension gurus here done? I'm trying to soften the front a little, current setting is full still as per the H&R install instructions, so just having a play, will the adjust the rear to balance. Cheers Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted September 21, 2015 Do you mean adjusting the end links to avoid preload? Or changing the holes to ones further out on the bar? Or both? I have never had the luxury of avoiding preload (ie never had adjustable links), and have always had preload so had to have the wheels off the ground to have any chance of getting the links on. Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted September 22, 2015 Hi, I mean adjusting the bar, so the end links are in different holes. Both front and rear are adjustable. Quote Share this post Link to post Share on other sites
