Guest Andrew
Tyre Pressure
Guest Andrew
Hi,
Anyone with an M20 e30 what pressure do your tyres to? I have the 318 sticker in my car and it seems a bit low. Can someone just tell me what the sticker on your door says.
Cheers.
1.9 bar at the front 2.0 bar at the back if you have 14" rims.
Guest MSBOND
I have the same problem, i have 15x35 on my 318, they r gt radials, wodnt a clue wot the tyre pressure should be, they always seem alittle flat wen you use the ordinary pressure setting, any ideas? I may just contact a tyre specialist, see wot they recomend
I just run all mine at 36psi (14's 15's & 16's).
Feels fine, maybe a little hard, definitley in the low thirties though.
my 2c
crank it to like 45-50.. it will give you that hard suspension feeling lol :wacko:
nah mid-late 30's is always good... or call a tyre centre if your that worried about the pressures :P
32 psi rear 34 front. real sticky
