Dirtybimmer
Where to buy speedo parts
Can anyone help me where can I buy replacement gears for an e30 odometer places ive rung do the whole gauge or repairs but I just need the gears?
I've bought them from EBay or Garagistic sell them too
http://store.garagistic.com/odometer-gears
You need to know if you have VDO or a Motormeter branded ODO - they also do MPH if you by chance have one in miles
Edited by Raerae
I have a spare set from garagistic.
For km motometers there are two types, i didn't want to pull it apart till i had parts to put it back together, so if you need type A I'm pretty sure that's the set i didn't need. You can have for cost plus freight to you, call it $50 couriered.
You need to count or read the tooth count on each gear to work out what set you need
Edited by Charlie F.
Thanks charlie I will pull the cluster out to tomorrow and find out which one I need and get back to you
No Worries, The set I have available includes: 12 + 44x16 + 40x28 + 28x22
If it doesn't suit you I'll just freight it back to the USA for a refund, garagistic will do that if you ask :o)
I checked surprisingly the whole cluster was held in by one screw but I need set b unfortunately so ebay it will have to be but thank you for the help
Are these gears still available? I will check what I need, hopefully this will work
The set i have still is yes.
