EuroAllDay 0 Report post Posted November 2, 2015 Is there anyway to get this working, or anything that could be wrong? 3 of my friends also have e46s without an alarm and they flash for deterrence. I have confirmation enabled which I heard is meant to enable clown nose as well, does something else need to be enabled via programming? Cheers. e46 328i 1998. Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted November 2, 2015 is it a jap import? IIRC there was something about the clown nose on imports being a receiver for the IR key, not a light for the alarm like they are in NZDM cars. Certainly none of the clown noses on my imports have ever flashed (E46 and E39). Quote Share this post Link to post Share on other sites
EuroAllDay 0 Report post Posted November 2, 2015 is it a jap import? IIRC there was something about the clown nose on imports being a receiver for the IR key, not a light for the alarm like they are in NZDM cars. Certainly none of the clown noses on my imports have ever flashed (E46 and E39). Yeah it is but there is LEDs under the clown nose. :/ Quote Share this post Link to post Share on other sites
dkonsta1 109 Report post Posted November 2, 2015 These are the infrared receivers not leds. Correct me if I am wrong. Quote Share this post Link to post Share on other sites
andyb184 7 Report post Posted November 5, 2015 (edited) you are wrong, the clown nose contains two LEDs from factory. The IR receiver is inside the mirror. You can carefully pry it out with a flathead screwdriver and pull it off. There are 2 reasons why it doesn't flash: it's probably not wired to the General Module. Second, you need to code your car and set DWA (Alarm system) to active. Here is what you can do to see if it's pre-wired: Unsnap the mirror plastic cover and pull the plug connector to see if there is a wire at Pin# 9. I think it's grey/black with thin yellow marks. This runs to the GM5 (X254 / 26-pin, black connector) Pin# 23 and feeds the LED. as an example, in the picture below the wire is missing.... Edited November 6, 2015 by andyb184 Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted November 8, 2015 check the fuse first. Could be missing or blown. mine was. Quote Share this post Link to post Share on other sites
andyb184 7 Report post Posted November 29, 2015 (edited) Is there anyway to get this working, or anything that could be wrong? 3 of my friends also have e46s without an alarm and they flash for deterrence. I have confirmation enabled which I heard is meant to enable clown nose as well, does something else need to be enabled via programming? Cheers. e46 328i 1998. just out of curiosity, what did you find out? Edited November 29, 2015 by andyb184 Quote Share this post Link to post Share on other sites
