andy hollis 0 Report post Posted November 19, 2015 The window winder on my 1975 2002 has a worn mechanism on the driver's side. Are the winders specific for each side or can I use a winder mechanism from a left hand door to replace the worn parts on the right hand door? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted November 19, 2015 don't know , but I do have some e12 1977 525 manual window regs if they are any help for parts Quote Share this post Link to post Share on other sites
andy hollis 0 Report post Posted November 20, 2015 Thanks for the reply Brent, I've pulled the broken assembly out and sent it away for welding. Not sure if it will be a fix, but if it isn't I'll take a picture of the broken part and post it. If what you have is the same that could be the solution. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted November 20, 2015 If you put up a pic I can try take an equivalent one of a passenger side, to compare. Quote Share this post Link to post Share on other sites
