Mr Vapour
wtb e28 rear end.
I'm just seeing what's out there at this point.
I'm looking for a e28 rear subframe and everything bolted to it
What year have both types
Excuse my ignorance on this . But I don't know the difference.
I'm planning on retrofitting it in to my e21. Bigger diff, stronger axles and 5 stud.
If the differance is sick and drum I after disc .
I've got an e34 rear subframe from an 88 535i if that works
Thanks for the offer, but it needs to be an e28 subframe.
IThey are a simmilar design, just bigger, so the beam just needs to be narrowed and it's a simpleish fit.
Later model has the dog bones linking the beem to the trailing arms for better handling have both types
This is good. All the e21 information just says to use a e28 sub frame and associated parts.
Is there any difference in how the shock mounts ?
I also read today that there are different angles on the arms .
Basicly I want what ever will give me the best handeling result.
I have to cut the ends off next to the arm mounts and weld the e21 mount tabs on, change the diff mounts, hand brake cables
I will send you a pm
David from the land west of the Bombays has sorted me out. Got a LSD in the package also. Good to get it sorted.
Thanks for the input gents
