kko110 4 Report post Posted January 4, 2016 Hi there, Anybody got some spare (not bent) rear trailing arms for a BMW e30? And is close to Tauranga? Cheers Karl Quote Share this post Link to post Share on other sites
richard 384 Report post Posted January 4, 2016 Is this what your after http://www.trademe.co.nz/Browse/Listing.aspx?id=1010403309&ed=true Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 4, 2016 Got some in Hamilton $100 but not home until the 8th Quote Share this post Link to post Share on other sites
Paragon 14 Report post Posted January 4, 2016 Got some with discs, calipers, handbrake cables, a pair with drums and cables, a pair stripped down , - take your pick . South auckland Quote Share this post Link to post Share on other sites
kko110 4 Report post Posted January 6, 2016 Got some with discs, calipers, handbrake cables, a pair with drums and cables, a pair stripped down , - take your pick . South aucklandAny with abs holes that are e30 and not e36 ti? If so how much? Are you around papakura? Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
kko110 4 Report post Posted January 6, 2016 Got some in Hamilton $100 but not home until the 8thDo they have the abs holes? Definitely e30 and not e36 ti? Any with abs holes that are e30 and not e36 ti? If so how much? Are you around papakura? Sent from my SM-G900F using Tapatalk Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Paragon 14 Report post Posted January 6, 2016 I have a fair selection of swing arms, none have abs holes. One pair came of a late model 320i and it had abs fitted, but not on the rear. The wiring was there but no rings on the half shafts or holes in the swing arms. You may have to search hard. Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 8, 2016 They do not have holes for abs sensors sorry Quote Share this post Link to post Share on other sites
Paragon 14 Report post Posted January 8, 2016 I have plenty of swing arms then. Two different castings from what I can see. A pair with drums, the others discs. Quote Share this post Link to post Share on other sites
