kko110
WTB: E30 rear trailing arms
Hi there,
Anybody got some spare (not bent) rear trailing arms for a BMW e30?
And is close to Tauranga?
Cheers
Karl
Got some with discs, calipers, handbrake cables, a pair with drums and cables, a pair stripped down , - take your pick . South auckland
Any with abs holes that are e30 and not e36 ti? If so how much? Are you around papakura?
Sent from my SM-G900F using Tapatalk
Got some in Hamilton $100 but not home until the 8th
Do they have the abs holes? Definitely e30 and not e36 ti?
I have a fair selection of swing arms, none have abs holes. One pair came of a late model 320i and it had abs fitted, but not on the rear. The wiring was there but no rings on the half shafts or holes in the swing arms. You may have to search hard.
I have plenty of swing arms then. Two different castings from what I can see. A pair with drums, the others discs.
