Jpclarke89 20 Report post Posted January 16, 2016 Hey guys, So I've got an issue with my high stop light in my e36. I've replaced the bulb and it still isn't working. I occasionally get the "brake light circuit" warning on my dash but both other brake lights work fine, so I'm assuming a pedal switch failure wouldn't affect just the high stop light? Are there any other easy fix methods I could try before digging in to find a wiring issue somewhere? Quote Share this post Link to post Share on other sites
Jpclarke89 20 Report post Posted January 16, 2016 Thanks will look into it. High stop light never functions, number plate lights are working fine Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted January 17, 2016 i concur with Ron, the wiring can also affect the boot locking. Easy enough to pull the boot back and check for broken wires. both of mine have had broken wires. http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/308129-e36-owners-check-your-trunk-wiring.html Quote Share this post Link to post Share on other sites
Jpclarke89 20 Report post Posted January 18, 2016 Cheers guys all sorted Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted January 19, 2016 and the solution was? Quote Share this post Link to post Share on other sites
Jpclarke89 20 Report post Posted January 19, 2016 The contacts in the light housing weren't matching up with the contacts in the bulb housing correctly. Just had to reach inside and bend the light housing contacts out slightly. Easy fix in the end Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
