HaNs
E36 328I Track Car
Sold this car a year ago and purchased it back.
Thought i better post it here
Replaced driver and passenger's side door handle mechanisms
Repaired drivers side power window regulator with new slides
Repaired door cards
Replaced rear vent window seals
Replaced rear windscreen outer seals
Installed H&R Cup Kit (matched shocks and springs)
Installed ECS tuning rear strut tower reinforcement plates.
Installed Msport chin spoiler front lip.
Replaced water pump with new unit with metal impeller
Replaced thermostat
Replaced thermostat housing with aluminium unit
Replaced upper and lower rad hoses
Replaced radiator cap
Replaced LCA bushings with purple powerflex.
Replaced RTA bushings
Installed poly RTAB limiters
Fixed the PS fluid leaks & replaced fluid.
Style 22s with near new Dunlop Direzza Z2 star specs (200 treadwear semi-slicks).
Plan is 8 point cage, new rear diff and aftermarket LSD, racetech 4009 seats, new brake lines and fluid. Trying to keep to cheap OEM parts. Not out to win any series. Goal is club events and maybe a short targa.
Edited by HaNs
  • Like 1
80km of track work and drove it home
post-4041-0-14672100-1454479855_thumb.jp
  • Like 1
New lip
Weight loss
Loom labeling so i know what i can remove later
Test fitting a Racetech 4009HR seat
Edited by HaNs
  • Like 1
Oh and a nice rear diffuser being made in Russia for me
  • Like 4
Great to see this getting thrashed about. Gone to a good home :')
Moved back home haha
When it's all ready come for a drive
  • Like 1
Nice car, where did you get the new front lip?
eBay
Sounds good! Keep us updated with your progress :)
Kill switch and remote pull thanks to Palmside
Edited by HaNs
Very Nice. Is that Shim's diffuser? looks to be made a lot better than Mateo's version.
Fancy Wide, new kids on the block by the looks of things
Yeah, that's Shim. Let us know what the quality/build is like, looks really well made compared to anything else on the e36 market.
Edited by Daniel0663
I want their front splitter but wont ship or sell me the template.
Edited by HaNs
I will be willing to sell mine if you want, i would rather run a AC lip on my e36 at the moment so have no need for one. Are you familiar with Jeff's felony form e36? i made that front splitter design and would suit your needs perfectly. Shoot me a PM or add me on FB and we can discuss in detail.
Seats are made and should be here Friday, asked KBM to sort me some seat bases
Kill switch installed, but have a cut at 2,000rpm in first gear only...odd issue.
New plugs/oil filter and fuel filter arrived.thanks to Fabian at CJBMW Hamilton
3.64 ratio diff arrived thanks to Andy
Seat and other bits are here
what type of seats are you going use adjustable mounts or solid mounts
Racetech 4009, one wide and one normal. Going fixed for now.
Another 100km on track at Hampton downs today, best was a 1.24.5 lap
Need to change fluid, pads, rotors and lines as brakes feel f**ked. Will get rid of aircon/looms/sunroof and tidy up driving and hoping for a 1.21 at least
post-4041-0-29144300-1456027619_thumb.jp
  • Like 3
Good excuse to upgrade e46 330/328 brakes/race pads? 330 with e46 m3 rotors would be mint.
Dion is running e46 m3 rotors with 330.
Diffuser is looking real nice, notice much difference?
