21inch745 1 Report post Posted February 15, 2016 (edited) Hello, Since I bought the car the bootlid hasn't been able to be opened without the use of the actual key being used at the boot, Once opened with the key I can press the FOB boot button and it will lift the boot up, Press the button on the boot to close it and the boot will drop down softly, but the lock doesn't engage (the electronic part which seems the tighten the bootlid down) I have fiddled with the lock switch inside the center console and this doesn't help either, I'm really stuck with this as I have owned it for 3 months and I still cant get the damn thing working, fuses all check fine... any help with this would be highly appreciated, Cheers, Ben *edit - after having a look on realOEM it appears to be my "Trunk Lid Power Lock Drive" that isnt operating for some reason Edited February 15, 2016 by 21inch745 Quote Share this post Link to post Share on other sites
jonoe30 53 Report post Posted February 15, 2016 (edited) Not solving your problem directly, but did you happen to purchase the car from a dealer? If so if you're inside 3 months they should remedy the problem for you.I realise most people are pretty clued up on this, but just thought I'd check. Edited February 15, 2016 by jonoe30 Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted February 15, 2016 http://bimmersport.co.nz/topic/51425-2004-e65-745i-nz-new-parts-car-low-ks/?hl=745i Quote Share this post Link to post Share on other sites
