Matich 6 Report post Posted February 21, 2016 Went to put down my drivers side window for some fresh air and the entire window fell forwards into the door. Turned out that the clips had crumbled apart as well as these regulator arms that went with them. I've replaced the clips but cannot figure out how to get these arms back together, I opened up the passenger door as a reference but this door's regulator arms will just not screw/clip/pop anything into place. are these arms even meant to be reattached? or should I just replace the entire unit itself. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 21, 2016 You need a new regulator Quote Share this post Link to post Share on other sites
