Gus
Motronic to Ljet
someone on here as done it....cant remember who....how did you go about it?
Matt, was it you?
Guest Andrew
Matt, was it you?
graeme - on my car.
And Matt.
V V easy thinking about it now - you have all the bits there (assuming you get the henna)
Cat out the of bag :ph34r:
Edited by bravomikewhiskey
your car ljet -> motronic...i want it backwards. matt...get your ass here
What are you trying to do Gus, fit an L-jet engine to a motronic car or just make a motronic engine run on L-jet management? The former is easy the latter is crazy.
haha Looking back a year or 2 ago I l can't believe we made my mates M20B25 ran off a 320i L jet ECU and loom. ran real well, (too well in fact :( ) It just shouldn't have worked
lookin at making a dual purpose car..320 engine for racing, 325 for fun....thinking about it...probably wont but am curious.
why crazy? brings in a whole new world of timing advance?
could always make the 320 run motronic...but wheres the fun in that?
Crazy, because the L-jet ECU only has a fuel map for a 2 or 2.3 litre engine. Being able to adjust the timing is pointless if you can't get enough gas into it.
what ARE you guys talking about? is it a new ecu and injectors and timing or something??? is it a good value for money performance upgrade ;)
thats why I can't believe my mates worked so well.
Would it be possible to get a custom chip for a 2.5 L-Jet? Easy enough to come by for motronic. Still sounds like more trouble than its worth.
Chris- They are talking about the different engine management systems. Pre FL cars run a fuel managment system call L-Jetronic while facelift and all 325i use an engine managment system called Motronic. L-jet is an older system, advantages are you can advance timing and is easier to convert to aftermarket ECU. Stick with what you have. Motronic 320 makes more power than Pre FL 320 anyway
Edited by petone
my cock, is bigger than yours..
my balls, are bigger than yours..
you can touch them, but i have to charge
