dirty36
10mm wheel spacers e36
I'm after two 10mm wheel spacers asap cheers. 5x120. Located in Wellington but can pay for shipping.
Can do 15mm if that helps.
Yeah that should work, just need more clearance so the inside of my rim will stop hitting my coilovers. Where are you based?
I have 10mm spacers on the M3 track car currently but they are flat and don't have the hub centric ring so don't leave a lot of hub exposed to support the wheel. I suspect they won't pass upcoming cert inspection (and not good for track work) so I'm looking for a set with hub centric ring.
Geoff, can you PM me about costs / etc for your 15mm spacers?
  On 3/19/2016 at 5:44 AM, dirty36 said:
Yeah that should work, just need more clearance so the inside of my rim will stop hitting my coilovers. Where are you baseWellington
Wellington. You can call me on 021 449 242
