Thomay 4 Report post Posted March 20, 2016 is this possible ? i have a rather tidy 82 318i project that i plan on swapping the steelies for basketweaves, will this require spacers? Quote Share this post Link to post Share on other sites
Olaf 3425 Report post Posted March 20, 2016 (edited) looks like they're both 4x100 PCD, centre bore 57.1... 5.5 or 6J with ET35. take a look around at wheel-size.com could be a go. HTH Edited March 20, 2016 by Olaf 1 Quote Share this post Link to post Share on other sites
Mr Vapour 76 Report post Posted March 20, 2016 No they will not fit with out spacers. factory offset is 15ish. The e30 wheels will mostproberbly foul the outer tierod. don't quote me on this but they are not easy to get wheels for. Also if you are planning on upgrading the brakes in the future then the 14s will most likely be to small. If you use 323 on the front you will be ok but if you go Holden or Volvo calipers you will hit the .Aliper with the wheel. Best bet is to try them out and see. 1 Quote Share this post Link to post Share on other sites
Olaf 3425 Report post Posted March 21, 2016 thanks Brock, I should have (and meant to) add that someone with the actual experience will be along shortly Quote Share this post Link to post Share on other sites
