Matth5
Leaky coilover repair/replace recommendation
BW E92 335i Coupe
KW V2 Coilovers
Was trying out the damper adjustment for the first time when I noticed my right rear shock leaking oil right out of the adjustment slot (the damper adjustment tool goes in there).
I'm in the east Auckland area.
Who in the area could repair these? Would it be worth a rebuild or should I replace it?
Pic:
Edited by Matth5
Looks like it's as simple as ordering a new insert from the local KW distributor and getting any local garage to install it. Not a bad issue after all.
