tankguy
WTB: e21 small bearing hubs
I need a set of small bearing front hubs to complete a brake upgrade on the 2002. These hubs were on e21 316i, 318i and 320 4 cylinder cars.
The inner diameter of the hub is 39.2mm and the stub axle diameter that it mounts on is 29mm.
Sent from my iPad using Tapatalk
I am pretty sure i will have a spare set ( or 3) lying around, just 2 front hubs?
Yes, just two front hubs. Must be the small bearing version. Thanks
I will check in my storage tomorrow and let you know.
Thanks
Any joy aja540i?
Sorry, change of plans, will measure up in the morning for you.
Aja540i, did you get a chance to measure up the hubs?
39.8 ish on the ouside race, 50 ish on the inner race,
post-17842-0-09008100-1461537037_thumb.j
Edited by aja540i
Great. Real OEM has inner bearing as 29x50.29, outer bearing as 17x39.87. Thanks for testing the time to check for me. How much do you want for the pair? Where are you located?
Im in Auckland, how does $30 plus shipping for the pair sound?
$30 for the pair is fine. Where in Auckland are you? I'm up every couple of weeks so could maybe collect? Otherwise, depending on your location, you could drop off at our office at either Mt Wellington or Avondale?
