325_driver 422 Report post Posted January 19, 2006 hey some thing just came up its the locks ... ? wondering whether ill need new ones or need to do a bit of adjusting but basically what i think is causing the problem is the rear right passenger seat lock i cant unlock it either with a key or with ma hand.... wondering whether taking the door off and having a search will be able to fix it ? because once i lock the car. central locking makes a loud drilling sound and then usually results in me having to use a great deal of force in opening it again and putting the key at risk .. ( so when i have the car unlocked the rear right door is still locked .... thus ma assumption is affecting the driver door also ? ) so new locks ? or rear door comes off and i have a fiddle round ? im having a chat to steve at some point ... hes on holliday some where cheers Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted January 20, 2006 The back door lock can't effect the drivers lock. Sounds like the central lock motors are just worn out. Take your door cards off and have a look if there is any obvious damage or wear to the motors. Could try cleaning and relubricating the lock machanisims too. I have plenty of spare motors if you need new ones. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted January 23, 2006 so ur saying the 2 days problems are seperate and have nothing to do with each other ? like the back door will have a different problem to the front so in that case rear lock is jammed front lock is about to die and central locking is fine, it makes that noise obviously cause the rear door is jammed sounds like some thing close ? nothing some good crc wont fix and a bit of fiddling Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted January 23, 2006 so ur saying the 2 days problems are seperate and have nothing to do with each other ? like the back door will have a different problem to the front so in that case rear lock is jammed front lock is about to die and central locking is fine, it makes that noise obviously cause the rear door is jammed sounds like some thing close ? nothing some good crc wont fix and a bit of fiddling Your on to it :thumb: Quote Share this post Link to post Share on other sites
