Hartage 0 Report post Posted January 25, 2006 Not sure how the work is going on this, but. I have done exactly this change, if i understand what you are saying. Took 1991 320i with broken cam belt and most valves bent. Replaced the motor with 1985 323i motor and put the manual gearbox in it as well. No plugs on gear box all on motor. Used all parts off the Motronic '91 car, Inlet manifold, loom, moved the Dissy to front of cam, basically changed every thing that was on the face lift motor and put it on Pre face lift. Then got a chip done in the UK to run the 2.3 motor with Motronic ecu. It will run on the 2.0 lt motor chip, but is MUCH better on bigger chip. Also had it ramped up to give better performance. All round a smooth faster car than the 2.0 . If you need more info PM me. Quote Share this post Link to post Share on other sites
petone 0 Report post Posted January 26, 2006 I was waiting for you to chip in, I had an idea you did the exact same thing. Random question- what cars have the sensors on the G/box? I know early 325 motronics but anything else? Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted January 26, 2006 the only different to your conversion the motor you put in was a facelift model to the one I'm putting in. Just had a quote on getting it done @ BMWorkshop.. I think its fair to say DIY Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted January 26, 2006 Was just thinking about the Hp of 323's . The later ones were rated at 110kw /150hp (hopefully you've got the 150 hp version). Can't remember if the difference was compression or camshaft. They are a good engine , lots of torque around idle (longer stroke than 325) ,They are a bit thirsty on the gas , maybe motronic will help this a bit. If you stay with Le injection you won't need to remap if you go filter / exhaust mods later on. Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted January 26, 2006 The 323 motor that went in to mine was PRE FACE LIFT. 150hp and with the uprated chip probably giving that at the wheels. I Hope! Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted January 26, 2006 (edited) No I mean the engine itself had a facelift - went from 139 - 150 horsepower. This one is only the 139hp version I'm afraid. Edited January 26, 2006 by E30stz Quote Share this post Link to post Share on other sites
