dennystone
Engine paint
I have tried a few different with mixed results
Next time I'm going 2K epoxy.
And yes it will brush on .
  • Like 1
Thanks, Brock
I've had good success using POR15 for engine blocks and gearboxes. I just brushed it straight on after cleaning. No peeling or anything.
Hi Mateja, what is POR15?
http://www.por15.com/
It was originally a rust treatment paint but they make all sorts now. I just used the regular stuff in the tin that you apply with a brush:
http://www.por15.com/Rust-Preventive-Coating_c_11.html
Thanks very much Mateja, I see the distributer is in Greymouth.
No problem. You can get it from Autolink/Colorworks in Penrose and most other paint and hardware shops as far as I'm aware.
  • Like 1
