francoisv 466 Report post Posted June 30, 2016 (edited) As per the title, does anyone know where the reverse signal is generated from on a 2000 E38 735? Its for the Rusta project that I have 99% completed the wiring up, and the E28 Chassis has a the reverse lights but the E38 LCM does not have an output for reverse. Im told it make come off the IKE / Cluster, PIN 25, but PIN 25 is blank, so I will try connecting a wire into this and test it today.However, I would like to find another point of reverse signal if PIN 25 doesn't work out. thanks heaps Edited June 30, 2016 by FrancoisPV Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted July 2, 2016 Solved Quote Share this post Link to post Share on other sites
