d.p.n.s 15 Report post Posted August 13, 2016 ok soooo car is a nz new 1993 e34 520ia touring my car failed a wof on dash lights..basically turning signals on the dash dont work [fixed now as bulbs blown ] high beam light on dash not working [ fixed now as bulb blown] now down to the airbag...so airbag light doesnt come on when i turn the key or go out once i start the car [pretty much because it doesnt come in the 1st place] there is a light on the on the steering wheel .this to doesnt come on or off. the bulb in the dash is fine as i checked it. any ideas please.? cheers [ Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted August 14, 2016 if you have the early steering wheel with the built in airbag light . there wont be a dash airbag light . all the electrics for the airbag and impact sensor etc are all in the steering wheel. there is a 3 pin steering wheel contact system . check there is power there etc . maybe the unit in the steering wheel has failed (common enough) , just replace the wheel with another one the same or swap it for a non airbag sports wheel from a early e36 non airbag car etc. most early e34 models had no airbags and some inbetween models had optional or retro fit airbag setup like what you have. see pics Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted August 14, 2016 yes mine is the same as that mate. i pulled it a part today and when i got down to the wee light for the airbag 1 wire had broken .. so i just soldered it back on put it back together and it works.. the light comes on when i turn the key and then goes out..[like it should i imagine ] but then a bout a min later it comes back on and stays on. 1 Quote Share this post Link to post Share on other sites
