glen.riley.1990 27 Report post Posted September 29, 2016 Does anyone out there have a set of N62 main bearing caps that i could have a look with a trial fit to buy if the work? Im looking to adapt an N62 oil pump to an M60, the mount points line up with the mains on the M60 but the M60 main caps have recesses for the bolts where the N62 has flat surfaces for the pump to mount to. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 29, 2016 You can't swap caps between blocks- the caps are line bored as a set with the block 1 Quote Share this post Link to post Share on other sites
glen.riley.1990 27 Report post Posted September 29, 2016 (edited) Quote You can't swap caps between blocks- the caps are line bored as a set with the block Cool thanks for the answer Glenn. take two... Edited September 29, 2016 by glen.riley.1990 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 30, 2016 What are you trying to achieve ? , if you don't mind me asking .... PM if you like Quote Share this post Link to post Share on other sites
