allan
Oil leaks M54
Topped off the oil today after replacing the sump gasket on the ti. While in their fitted new engine mounts, dipstick to oil separator hose, "O" ring to the dip stick , "O" ring power steer res, oil filter, air filter  and plenty of engine degreaser  to clean the under side panels etc. The inside of the sump was not a pretty sight had a tide mark around it and heavy staining  took some cleaning but got their in the end. Had previously replaced the cam cover gasket and rubber washers as these had been leaking which I hoped would have fixed the problem hoping against  all odds. But no it was from the sump gasket so with that fixed maybe just maybe might get to have a little drive time before something else comes along.
