JoKer
E34 540i Indicator woes
Started off last night with no Left indicator : weird
Pull fuses 3 & 6, seem ok switch them around & now the lefts are stuck on, righ is normal & hazards make the headlights flash once then nothign with the LEfts still stuck on
Have had a dicky battery for the last month & jump started it once or twice, so fearing the worst
where should I start looking next?
image that is of no help at all I took just now
14713713_10154557305667456_4368160918502
"left" is still stuck on :/ thats why i have the blue / 15 A fuse out
recently replaced the Low beam bulb on the same side too with the same hella bulb : potential cause? may remove it & try
was like $10 bulb
Edited by JoKer
have narrowed it down to the relay closest to the word "check" on the module 2nd from bottom
LOL Sig removed VV bit ott innit?
Edited by JoKer
so got around to a WOF check & still no joy, fuse in all lights work on Hazards & Mechanic recommends taking to a Stealership or possible stalk malfunction
help?
Edited by JoKer
I should have some spare E34 relays and modules if you need them.
  • Like 1
Hi cheers & yeah turned out to be the relay
thanks for the response & all sorted now :P
