mynbmr
fluctuates rev counter
1994 e34 530i automatic
my rev counter started to fluctuate all the time from 0 to red.
no rev fluctuate or loss off power in motor or gearbox.
any suggestions where to look thanks
If the speedo is working fine then it could be a possible instrument cluster fault. You should be able run the self test on the cluster, IIRC hold down the right knob on cluster with ign off, turn key to on position and let go.
