nz320i
offsets
whats the biggest offset on an e30 for 7" wide wheels??? i dont know much on this topic but i need some new wheels.. thanks
you will just squeeze on 17x7 with a 42mm offset, (with 45mm struts) if you have the bigger struts they wont fit. I'm not sure of max offset for 15" or 16" wheels. Ideally try and get something around ET25. Also have to make sure that the wheel clears the brake caliper, this depends on the design of the wheel.
Edited by petone
Go for ET24, i'm running 15x7 with a 21mm offset, my 205/55 tyres just fit so can't go bigger, 24 would be perfect.
