HaNs 226 Report post Posted December 11, 2016 ABS Pump $700, working find when removed ATS brand, from NZ new 328I 34.51-1162 291 10.0202-1043.4 Brands new rear rotors $60 for the pair TRW DF1539s Fits 316, 318 and early 325 by the looks Drum Diameter : 160,8 Bolt Hole Circle Ø [mm] : 120 Thread Size : 14,5 Number of Holes : 5 Height [mm] : 60 Centering Diameter [mm] : 75 Minimum Thickness [mm] : 8,4 Brake Disc Thickness [mm] : 10 Diameter [mm] : 280 Brake Disc Type : Solid Surface : Painted Quote Share this post Link to post Share on other sites
